can the NTP Server support be enabled in the BR1 Mini HW3 model?
We need it urgently for a transportation use case, where other systems sync to NTP server of the router.
@TK_Liew could you have a look here, please
If you look at the post here, probably would have an idea why the BR1-Mini series only could act as NTP Client.
If NTP Server is needed, the nearest siblings would be BR1 Pro 5G or BR1 Pro CAT-20, that you can consider.
