Hi I have a server reading the NMEA GPS Stream (TCP PORT 60660) from a Pepwave MAX BR1 in the field. It’s looks like it updates every 5 seconds, and appears to be eating a lot of our bandwidth. We only need the update maybe once every two minutes? Is there anyway to adjust that time? Changing the ‘Report Interval’ doesn’t seem to make any difference.
Do you think GPS Forwarding meet your requirement? You can adjust the interval there.
I could never get that set up properly with my application. I think I have figured out how to use the GET request to get a devices location with the API, and will likely switch to that to have more control over requests rather than a persistent connection.
