Our GPS equipped routers are capable of forwarding GPS information to external IP addresses. To configure this feature, please navigate to Advanced > GPS Forwarding:
Click Save, and then Apply Changes to save your configuration.
How many servers can one forward to?
Make sure your device always running latest firmware then you should able to define up to 4 forwarding servers.
is there any option for device in the peplink’s LAN to pool GPS coordinates directly from peplink device? Is it possible to do any modification of CGI-BIN scripts?
Best regards,
Gregor
You can access the GPS data directly by connecting to the raw port. See
Hi, as a functional request, is it possible to get GPGZA supported in the GPS forwarding function?
It is currently missing from the options in the menu.
We would like to log time and date as well.
Kind regards,
Gil
Hiya, I’m trying to identify the accuracy of the GPS data. I appear to get 4 significant figures for latitude and 3 significant figures for longitude. Is this data accurate? Does the system round off?
Best,
-Alex
