Hi all,
I am a Starlink beta user. I have read some helpful posts from others who are also in this same situation. I agree with what I have read that Peplink is likely to see a surge in consumer interest resulting from Starlink becoming more widely available.
As it stands, Starlink is fantastic for a ‘better than nothing beta’, but when it comes to business use, a secondary WAN with as seamless of single-WAN-IP failover as possible really is necessary, specifically for video conferencing. Other contexts that will be similar would include gaming where a brief Starlink-esque interruption can easily lead to landing in a lobby.
Until my peplink showed up, I had been using Speedify, but know very little about that company and so was glad to be able to stop using them as a VPN provider.
I have been fumbling my way around Peplink and am currently trying out a few different options. First, I have a PepVPN tunnel setup with an AWS endpoint I created by following the tutorials on here. One of the challenges there is that ca-central-1 is on the wrong side of the country for me. Hopefully AWS decides to setup a ca-central-2 soon further west
Anyhow, in my tests with PepVPN this is adding 30-40ms of latency to my ping.
I also am trialing SpeedFusion Cloud. Like AWS, the datacenters are on the wrong end of the country for me, adding latency to the equation. However, since SFC has the ability to do WAN smoothing and FEC, I think it is the preferable option for the time being. (Unless someone can correct me, it looks like WAN smoothing and FEC are not available for PepVPN / AWS deployments?)
Anyhow, I have a few questions for my setup. For context, besides Starlink I also have a “smart hub” from the telco which is LTE based. That connection, while honestly pretty rock solid, has several limitations: 1TB data/month, and 25Mbps down throttling. Notwithstanding that, it is apparent to me that the telco has QoS in place for business things because I have almost never encountered issues with zoom, teams, slack, etc. Anyhow, the questions:
Because of the increased latency, I do not want to route all my traffic, even all of my business computer’s traffic through the SFC. Because the use is narrow, I have setup my lone SFC tunnel to use “Normal” WAN smoothing and “Low” FEC. In fact, the only scenario in which I want to route traffic to SFC at all is for zoom, slack, and teams calls. But it is unclear how to achieve this. My understanding is if I associate my work machine through the Speedfusion Cloud portal’s device selector it will route all traffic from that device to SFC. Yet, if I try to use Outbound Policy to do this, I have no way of specifying application-level routing, and from what I’ve read on here using DNS isn’t going to cut it either.
Is using both WAN smoothing and FEC at the same time advisable? Or is it more of an either/or thing? I am fine with using more of my 1TB allowance if it means having that rock solid connection for presentations/conference talks/etc.
I noticed that Slack is not listed at all on the VOIP list. Besides DNS, is there any sure fire way of capturing Slack VOIP traffic in a rule?
The latency I’m getting through PepVPN/SFC is around 90-110ms on average (vs 40-50 on Starlink normally and 15-25 on LTE). Does anyone have any context for how much of an impact this will have on video meetings?
I do have the option of adding another WAN connection from a different cell provider hitting off a different tower. That connection is unlimited data, up to 50Mbps down and a godawful 2-3 Mbps up. I’ve also had periodic issues with pretty high latency on that connection. I cancelled it when we got Starlink but have been flirting with the idea of adding it for a triple redundancy. Would this be going overkill? I realize this is subjective but just curious on what other people are doing. I am an internet snob so it is honestly tempting to have as many redundancies available no matter what, and I could probably write off one of the connection costs as a business expense.
If any other Starlink user has figured out the static routing problem (described in this thread: Starlink and Peplink Balance ) please let me know. One thing I discovered, is that until the Starlink dish gets an actual IP from space it works with zero configuration (it defaults to a 192.168.100.* address) but as soon as it gets a WAN IP everything stops working.
I think this is all I have for now. Thank you all for your time.
