Hi All,
I have a customer requirement to NAT local subnets to a specific private IP before the traffic is sent over a IPSEC tunnel. Does anyone know if this is possible and how it would be achieved?
Hi All,
@PepUserJ, is this what you are after?
Virtual Network Mapping on LAN > Network Settings page works as well, and this one will apply for most connections with remote peers.
You can enable the feature in the Help icon of Static Route Settings:
Then the Virtual Network Mapping section will pops up:
Perfect, thanks.
