Thanks to everyone that attended the second session yesterday.
Please join us at the same time this Friday for part 3.
I am going to summarise some of the FAQ
Administration related
Q - Will all sessions be recorded and be made available to the attendees?
A - Yes, the recording will be made available in a few days
Q - Can we have a copy of this presentation afterward please?
A - We will be publishing some of the slides but not the whole presentation
Q - How do best prepare for the PCE & mPCE?
A - Attendance of the webinars and study of our website & forum
Q - Do you need to achieve the PCE before taking the mPCE?
A - Yes. Please watch our first webinar as it is explained there - Recording Session ONE
Product Data Sheets
Q - Can we please have a copy of the spec sheet
A - All our existing products are available on our website, for new products Peplink Partners can email [email protected] and we will send it over
HD Dome & SIM Injector
Q - Do you need multiple ethernet cables to access the 8 sims in the sim injector?
A - A single network cable is required per Dome. This provides PoE and communication with the SIM Injector & network
Q - Can the Dome models be used without the SIM Injector?
A - Yes. you can put SIMs inside the HD Dome
Q - How many HD Dome’s can be supported by 1 sim injector when using an additional switch
A - You can support up to eight Remote SIM compatible devices with one SIM Injector
Q - What Peplink models are compatible with the sim injector at the moment? Only the domes?
A - This will be covered in the next webinar on Friday
Q - Are the new antenna’s and Dome’s 5G ready?
A - The Domes are not 5G ready. They currently come in up to CAT18 for the HD1 Dome. Our antennas are 5G ready.
Q - What is the recommended distance between the dome and the SIM injector?
A - There is no minimum distance but the maximum distance is 150m
Q - When you use the SIM injector + Dome, do you need a second cable to the ‘LAN’ of the Dome for the data? Or is the SIM injector working as a Smart Switch with full throughput?
A - No, a single cable is required between the Dome and SIM Injector. You then require another network cable from the SIM Injector to the rest of your network
Q - Is it possible to have dislocated SIM Injector from Dome over the Internet and have connected together by Speed Fusion?
A - Yes this is possible for the HD2 Dome but not the HD1 Dome because the Dome first requires an internet connection using a local SIM card.
Antennas
Q - Does Peplink support, or have, any type of best practice for measuring actual gain on antenna implementations?
A - It is up to the manufacture to supply the information regarding the actual gain of a particular antenna. If you need the info about our antennas, please contact us and we can share this data with you.
Q - How is your range at sea been measured, is it average. I’m concern about the line of sign and TX delay because of the distance.
A - The range you can achieve will depend on many things including (but not limited to); Antenna choice, antenna cables and length, cellular network coverage and antenna height
SD Switch
Q - On the 16 Port SD-Switch Rugged, does LAN failover activate if the switch loses power or is it just for a software problem?
A- The LAN Bypass feature automatically activates if the switch losses power.
