Max transit duo verizon certified
Hi!
Is the Max transit duo Verizon certified?
Hi Patrick,
have a look at the Datasheet
Yes, it is
Regards
Dennis
I think there is a difference here between Compatible with and certified.
Or am i wrong?
Indeed there is. However the Transit Duo has been certified since 2017 so its just a question of commercial contract compatibility. From my loose reading of the forum around this it seems Verizon don’t always allow some SIMs / contracts to work (the cheapest ones) preferring you have a commercial / m2m sim/contract.
The CAT18 Transit as the latest model is still going through certification:
And there is a thread with users working out what contracts work on that here:
