Last week I have bought a MAX BR1 PRO 5G Global version with firmware 8.4.0 installed. And have connected my Dishy via a POE injector directly towards the Peplink Router via Ethernet. (not the Starlink Ethernet dongle but via the POE injector data port)
I have setup my connection to the Pepwave max to the WAN port and setup according to the youtube video with MTU 1500 and DNS checks and also added the management IP 192.168.100.2 to be able to use the Starlink App without the Starlink Router. Also added SIM card 5G and added external WIFI.
Created a separate VLAN 1 on 192.168.101.1-255 dhcp is from 192.168.101.2 till 100 and Pepwave is accessible via 192.168.101.1 this VLAN is bound to my peplink AP WIFI SSID
Everything works fine, so Starlink app on iphone, I can also go to dishy.starlink.com but the Starlink WAN connection simply is not performing.
I have an internet connection but the DNS resolving / Ping times are extremely high. Also the speeds are extremely low 0,5Mbit download sometimes.
So opening a google.com takes 1 minute and searching does not even show.
I have checked it via LAN and via WIFI both the same results, Starlink basically does not work.
This is the cable setup and I have checked the cables on an old RV router which works perfect, I here get +/- 60mbit up and down when connecting to this wifi.
So I basically I know that the cables are working perfectly and my POE injector works perfectly.
So what am I missing here… what do I still need to configure.
