While at a campground the local WiFi signal was weak and possibly dropping intermittently. During this time the AP would appear to stop transmitting with my AP’s SSID not being visible. Without the signal I could not get in to the admin menu to troubleshoot further. It makes no sense that any activity on any of the the WAN ports would cause the AP to stop transmitting. A reboot would often solve it for a time. Is there any condition under which the AP stops transmitting?
Thanks for the info. I just checked the setting and is it already disabled.
What firmware version are you running?
8.1.1 I updated in the middle of this problem and it did not help.
