Introducing Marine Grade Stainless Steel Deck Mounts for Maritime Deployments
Protect your antennas and cables from harsh weather conditions and corrosion with our premium deck mount. This rugged and heavy duty mount is made from the highest quality Marine Grade Stainless Steel and is designed for deck and mast installations.
Click here for more information on the specifications or instructions on how to order.
FAQ
Which antennas are compatible with this product?
This deck mount is compatible with both our MAX HD Dome series and Puma series antennas.
I already have a maritime base, can I order the deck mount without the maritime base?
Yes you can! If you already have a compatible maritime base, you can order the deck mount “Without Maritime base”.
How are the Puma series antennas attached to the deck mount?
Puma series antennas can be directly attached to the deck mount’s cylinder (ACW-651). This means that you do not need the cap (ACW-650) if you are buying the deck mount for a Puma antenna.
Why are these parts split into 3 SKUs rather than all-in-one?
Peplink Premium Deck mounts have three different SKUs to support different product mounting options. Below are the most common mounting examples:
- Stingray antenna series: ACW-652
- Puma antenna series: ACW-651 + ACW-652
- MAX HD Dome series: ACW-650 + ACW-651 + ACW-652
We offer a modular design which allows users to select the options that they need for their applications. You may find more details on the Premium Deck mounts in this datasheet.
