Ref.: #31185, #31917
Details:
SpeedFusion may get stuck on “Updating Routes” if no devices are physically connected to a remote peer’s LAN port.
This issue arises due to an update in the OSPF protocol, which now recognizes the “link state” of advertised networks. If the link state is down for a specific network, meaning no devices are physically connected to the port, the network will not be advertised.
Affected firmware version:
8.4.1
Fixed in firmware version:
8.4.1s032
Workaround:
We have developed a special firmware, 8.4.1s032 (based on the 8.4.1 GA), which reverts this change, allowing OSPF to function as it did in version 8.4.0. However, if you need to remain on version 8.4.1, simply connect any device to the LAN port to activate it, and the routes will then be exchanged successfully.
In the next firmware release, we will introduce an option to enable or disable this behavior. For users requiring link state awareness for OSPF, there will be a dedicated UI to enable this function.
Here are the download links for the special firmware (8.4.1s032):
| Download Link | Product | Hardware Revision |
| Download | B One | HW1 |
| MAX BR1 Pro | HW7 | |
| MAX BR1 Pro 5G | HW1 | |
| MAX BR2 Pro | HW4 | |
| MAX HD1 Dome Pro | HW1 | |
| MAX Transit Duo Pro | HW1 | |
| Download | Balance 2500 EC | HW1 |
| Balance 310 5G | HW1-2 | |
| Balance 310 Fiber 5G | HW1-2 | |
| Balance 310X | HW1-4 | |
| Balance 380X | HW1 | |
| Balance 580X | HW1 | |
| Balance Two | HW1 | |
| EPX | HW1 | |
| MAX HD2 MBX | HW1-4 | |
| MAX HD4 MBX | HW1-4 | |
| MAX MBX Mini | HW1 | |
| PDX | HW1-2 | |
| SDX | HW1-3 | |
| SDX Pro | HW1-2 | |
| Download | FusionHub | HW1 |
| Download | Balance 20X | HW1-3 |
| MAX BR1 IP55 | HW4 | |
| UBR Plus | HW1 | |
| Download | Balance 210 | HW4-5 |
| Balance 30 LTE | HW3 | |
| Balance 30 Pro | HW1 | |
| Balance 310 | HW4 | |
| Balance One | HW1-3 | |
| Balance One Core | HW1 | |
| MAX 700 | HW3-4 | |
| MAX BR1 ENT | HW1-2 | |
| MAX HD1 Dome | HW1 | |
| MAX HD2 | HW5-6 | |
| MAX HD2 Dome | HW1 | |
| MAX HD2 IP67 | HW2-5 | |
| MAX HD2 Mini | HW1-4 | |
| MAX HD2 with MediaFast | HW1-4 | |
| MAX HD4 | HW1-5 | |
| MAX HD4 IP67 | HW1 | |
| MAX HD4 with MediaFast | HW1-4 | |
| MAX Transit | HW1-3 | |
| MAX Transit 5G | HW2-3 | |
| MAX Transit Core | HW1 | |
| MAX Transit Duo | HW1-3 | |
| MAX Transit Duo Pro E | HW1 | |
| MediaFast 200 | HW1,3 | |
| SpeedFusion Engine Cam | HW1 | |
| Download | Balance 1350 | HW2 |
| Balance 2500 | HW1 | |
| Balance 305 | HW2 | |
| Balance 380 | HW6 | |
| Balance 580 | HW2-3 | |
| Balance 710 | HW3 | |
| MediaFast 500 | HW1-2 | |
| MediaFast 750 | HW1 | |
| Download | MAX BR1 Mini | HW3 |
| MAX BR1 Mini 5G | HW1 | |
| MAX BR1 Mini Core | HW3 | |
| MAX BR1 Mini M2M | HW1 |
