I demo the speedfusion feature using the device as illustrated
but I found a problem, when I transfer file using 2 links wan the speed decreased by half around 30-40 Mbps = 3-4 MB / s
when I disconnect wan1 the speed corresponds to throughput max700 60Mbps = 7.5MB / s
is this an issue / bug?
Hi Rizal, the sims you used are from the same provider ?
I invite you to read this article http://download.peplink.com/resources/whitepaper-speedfusion-and-best-practices-2019.pdf
regards
Antonio
its directly connect using twisted pair patchcord
is the same provider?
ok i understand now!..
can you make a test with PepVPN Test ?
the result is still low, you should have got 100Mbps even with just a WAN .
very low , can you check if the speed port negotiated correctly ?
do you mean the speed on port?
yes under support.cgi of each peplink .
What is the category of ethernet cable ?
Cat 6
Where the support.cgi?
replace in the url index.cgi with support cgi
https://192.168.1.1/cgi-bin/MANGA/index.cgi
https://192.168.1.1/cgi-bin/MANGA/support.cgi
I have now checked the Max700 datasheet, the device has a maximum of 60 Mbps inside the vpn, so as a value there can be because you are at the edge of the band.
You can try doing the same test without vpn encryption, you should get a result close to 100Mbps
see the link: https://www.peplink.com/products/max-cellular-router/multi-cellular/#M700
Yes i know if max700 have troughput sf aes256 60Mbps
I mean if i using 2 links wan an why the speed drop around30-40Mbps
But if only 1 wan can full 60Mbps
You can see my capture transfer file above
I think it is due to the fact that the vpn overhead corresponds to 19%, however perhaps you should wait for the response of one of the Peplink team
I think not cause overhead beause still above 60Mbps sir in my calculate overhead
Ok thx sir i hope TK Liew answer my topic๐
Btw im technical peplink distributor from Indonesia
Nice to meet you
