I bought a Balance one core recently.
I configured a Dual wan load balancing setup (2x 100mbits down / 35mbits up) and the CPU was hitting 100% slowing down everything.
I reset the router, configure 1 wan via PPPOE (1x 100/35 mbits), speedtest single thread, and the CPU was at 60%… Without any setup other than the PPPOE.
Of course, I returned the item and got a refund.
I was wondering if PPPOE is just broken accross all the peplink devices ? A quick google search (and on this forum as well), shows a disturbing amount of results (like this one => Balance 305 throughput PPPOE)
So yeah, is PPPOE not an option with peplink at all, or is there a device that is working ? Because other than that, the os was a beauty.
Thank you !
Good day,
Unfortunately, I was never able to get a workable solution from Peplink. The firmware update did not solve my issue. PPPOE is a problem with Peplink products and it seems they are not addressing these issues.
I wish I had a solution for you.
Manuel Deroukakis 613-676-1466 (Cell) 613-632-5886 (Work)
| touch444719
February 22 |
Thank you !
That’s sad. Thank you for the quick feedback, and I’ll just move on and try something else.
Have a good one !
