We just received our Pepwave MAX Transit Duo cat 12 from an online vendor today. I immediately grabbed the IMEI’s (there are two) and checked compatibility on Verizon, AT&T, T-Mobile, and Cricket. It appears it MIGHT be compatible on AT&T, but appears to not be compatible on the others. I expected this with Cricket based on info from the folks at the Mobile Internet Resource Center. However, I am concerned after Verizon and possibly AT&T might not be compatible.
Am I checking this correctly? I’m afraid I just purchased a router (and antenna) that I cannot use anywhere without a hack.
Verizon: Check Your Device's IMEI | Bring Your Own Device to Verizon
The phone associated with the Device ID you entered is not compatible with the Verizon Wireless network.
AT&T: IMEI Error
Your device is incompatible with eSIM. We’ve saved you a step and added the SIM card you need to your cart.
Note: Nothing was added to my cart.
T-Mobile: https://www.t-mobile.com/resources/bring-your-own-phone
Bummer! Your phone is not compatible with the T‑Mobile network and will experience no service. Your handset must be compatible with LTE and VoLTE to connect to our network. Please upgrade to a new T‑Mobile phone that can give you access to our best coverage and fastest speeds on our network.
Sierra Sierra Wireless EM7511U
Cricket: https://www.cricketwireless.com/cell-phones/bring-your-data-device\
Apologies! This Sierra Wireless EM7511U EM7511U is not compatible with the Cricket Network due to network changes. Please visit cricketwireless.com/3Gnetworkshutdown for more details or see your Cricket store rep.
