I would like to know: Is possible work with balance 580 using Drop-in + VLAN ?
I need:
To connect my internet cable (ISP) on Balance 580 WAN1 with Drop-in.
To connect a cable from LAN3 (peplink) to eth3 (my firewall).
To connect a lan cable from LAN1 (peplink) to my switch core.
WAN1(peplink) will have a external IP (internet). Example: 200.200.200.201
ETH3(firewall) will have a externa IP (internet). Example: 200.200.200.202
LAN1(peplink) will have a internal IP with VLAN to my switch core. Example: 192.168.0.1
My switch is the gateway. Then, I will do the routes on it. When the packets are sent to internet the switch send to firewall and firewall send to ISP through the Peplink. When the packets are sent to SpeedFusion (MPLS) the switch send to Peplink.
But for this, I need that my switch talk with Peplink.
we were thinking about a different solution. we’d like to put wan with drop-in linked to our firewall (LAN3 <> WAN1) and, with a VLAN, link our core switch direct to peplink (LAN1). So, the traffic among MPLS goes through LAN1 (switch) and the rest (internet) goes through Drop-in (firewall).
