I have 5 WAN connection i need to setup on Balance 310X
Hi there!
I have 2 Peplink Balance 310X for 2 sites
The first site include 3 WAN internet connection, and 2 WAN MPLS connection, and the device only have 2 WAN interface.
I can use usb to NIC with for the 3rd WAN internet connection
And configure the MPLS connection on the network interfaces.
Now my question is, how I can include the MPLS in the speed fusion configuration.
Also how we can reach Peplink support
To answer your first question: more WANs. Check out VLAN on WAN: Virtual WAN FAQ
Regarding Peplink support, your first step will generally always be your Peplink preferred partner (the one that sold you the 310X)
Thank you so much @ChristopherSpitler,
This generate another question, I’ll need 5 Virtual WAN that will cost me 1000 EURO is it worth to do that purchase, or I can stick to use the 4 USB to NIC and Only purchase 1 VWAN and this should cost around 280 Euro.
Please if any one have go through this, worth to mention all those connection between 20 to 75 Mbps
