The VLAN Trunk on LAN feature is supported in Firmware 6.1. You can enable it via the following steps. With this feature enabled, the LAN port(s) of the unit will become trunk port.
Go to “Network > Interfaces > LAN”
Click the “?” as the screenshot below, then you can click the link to enable VLAN feature.
VLAN Trunk feature is enabled.
