Just started using a BR1 Mini and I’m trying to set up the app on my cell phone. Not the most IT literate, so what/where is the host name and device name?
Welcome to the forum!
When you are connected to your BR1 Mini, you can use its IP address which is 192.168.50.1 by default. Try that.
Hello @mulliganrj
If you have your device on InControl2 and you mobile is running an Apple iOS, then you can use the InControl2 App instead of the Peplink Router Utility.
Happy to Help,
Marcus ![]()
