FusionHub on Proxmox, any Pros/Cons?
We’re planing to migrate our currently running FusionHubVM over to a Proxmox Server. Should not be a real challenge to do so also directly with the RAW hdd image.
Are there any know Pros/Cons? Using the VirtIO-NetworkDriver is ok? I guess there is no way to install the qemu guest additions on the FusionHub OS itself or can it be installed via SSH?
Thx.
It works great, I wrote an article over here how to set it up.
https://forum.peplink.com/t/how-to-setup-a-fusionhub-with-proxmox
