I’ve tried searching the forums but can’t find anything matching what I’m looking for.
I’ve got a FusionHub instance on AWS with its default public IP. I also have two PepVPN clients connected with the configuration done in IC2.
What I’d like to do is set up an additional public IP address for the FusionHub instance, and use that for port forwarding to one of the PepVPN clients (a MAX BR1 running on Verizon LTE, so without a publicly routable IP).
Is this possible? I ask because the second PepVPN client, a Balance 210, has 5 public IPs per WAN, so I can use a different one for various servers, etc… I’m hoping I can do the same with FusionHub.
