I´m trying to force youtube to use only one wan, I put this domains whith the algotihm force
youtu.be
ytimg.com
Ytimg.l.google.com
i.google.com
but I always get 1e100.net using other wans.
youtu.be
ytimg.com
Ytimg.l.google.com
i.google.com
I had do some check for the domain 1e100.net and found that this is actually a hidden domain from google and there is not details info when the domain will be used and how the domain resolve work for the domain.
For more information, please refer to the URL below:
Beside that, the domain also registerd in multiple top level/root domain registered.
http://whois.domaintools.com/1e100.net
Just to check how you detect the 1e100.net is forwarded using other wans ?
Thank You
In active sessions show ips of 1e100.net and the wan using
We had perform URLs capture when accessing to youtube.com and we can’t found any request to domain 1e100.net. Beside that, we also further check on the DNS query from the PC to the internet regarding to the domain 1e100.net and there is no DNS requries to the domain as well. We don’t thinks the domain 1e100.net is require when accessing to youtube.
Base on my finding also, 1e100.net seem to be the reserve DNS pointer (PTR) for all google and youtube public IP addresses.
For more information, please refer to the test below:
Ping Request:
ping www.google.com
Pinging www.google.com [216.58.196.196] with 32 bytes of data:
Reply from 216.58.196.196: bytes=32 time=43ms TTL=51
ping www.youtube.com
Pinging youtube-ui.l.google.com [216.58.196.46] with 32 bytes of data:
Reply from 216.58.196.46: bytes=32 time=44ms TTL=51
Reverse Pointer (PTR) Check:
nslookup -q=PTR 216.58.196.196
Non-authoritative answer:
196.196.58.216.in-addr.arpa name = kul06s14-in-f4.1e100.net
nslookup -q=PTR 216.58.196.46
46.196.58.216.in-addr.arpa name = kul06s11-in-f14.1e100.net
46.196.58.216.in-addr.arpa name = kul06s11-in-f46.1e100.net
Thank You
You would need to create custom outbound rules using the following domains:
http://www.peplink.com/knowledgebase/use-peplinks-firewall-feature-to-block-youtube/
