Firmware version 8.5.2 Build 5581 Upgrade - Multiple Issues (Balance 20X)
I recently upgraded to Firmware v 8.5.2 Build 5581 (using the Check for New Firmware option within the Web Admin Interface, ie I did NOT do a manual update by downloading the file separately and selecting it in the Web Admin Interface). Since then I have experienced multiple issues:
  1. B20X reboots on its own at apparently random intervals anywhere from 17-138 hours after the last startup (without any admin/user intervention). This has happened 4 times in 10 days
  2. I use a schedule to turn on/off Wi-Fi AP SSIDs at certain times. While the Device Event Log shows the expected line entries at the correct time of “Schedule: [ScheduleName] turned off [SSIDx]”, the Wi-Fi AP SSIDs were NOT turned off and remained active. There was also a missing line entry “System: Changes applied (schedule)” in the Device Event Log immediately after the expected “Schedule” line entries, which explains why the SSIDs were not turned off. This happened the first time after the firmware upgrade but has not happened again
  3. when connecting an ethernet cable to a LAN port to log in to the Web Admin Interface from a computer, the Device Event Log was MISSING the usual line entry “Port: Port (LAN Port) status changed (link up, speed 1 Gbps Full Duplex)” that is always captured. Next, when in the browser connecting to the correct router IP address/port in order to log in to the Web Admin Interface, I received an error page “500 Internal Server Error nginx”. I have never seen that page before when accessing the Web Admin Interface login page and in order to get around it I had to manually unplug the router and power it down and then back up again to be able to log in to the Web Admin Interface successfully (where I confirmed the missing “Port” line entry I referenced at the beginning of this point #3)
  4. after this manual reboot (unplugging and powering up again), a client device failed to connect to one of the router’s Wi-Fi AP SSIDs and simply gave an “unknown error” message in the OS and refused to connect. However, on that client device I could connect to another Wi-Fi AP SSID broadcast by the router and once I had done so, I disconnected from that SSID and then was able to connect successfully to the first SSID (which had previously been unable to connect with the “unknown error” message)
I do not use InControl and the router is set to allow Admin Access from local LAN only. It is locked down in line with Michael Horowitz’s Router Security website advice (albeit he gives it for the Surf SOHO).
Post firmware upgrage, the behavior suggests that there are either lots of bugs here or, more ominously, that the router has been hacked (maybe in the the firmware upgrade?). #3 above is especially worrying.
For now, I have rebooted back to the previous v 8.5.1 Build 5531 firmware and am running that on the router, but frankly I have concerns about the integrity of the router given what I have observed.
I am unable to see any signs of compromise by inspecting the Device Event Log. I am unable to view the Diagnostic Report I have downloaded (as other Peplink users have previously posted about).
Have others experienced any similar issues following the v 8.5.2 Build 5581 firmware upgrade? I saw on the Forum that one of the earlier Release Candidate versions of this firmware version had problems with the router rebooting on its own (my #1 above).
Cheers
Charlie
I too have been encountering stability problems once I upgraded my Balance 20X routers to firmware 8.5.2 Build 5581. Now they tend to restart themselves at random intervals every day or so. The previous firmware would run for hundreds of days without any issues so this new behavior is quite unexpected. Seems to me like there could be an uptime reliability issue with the firmware.
Hi. We have not seen this but Peplink has a strong interest in reliability and bug-free firmware. I’d recommend you submit a ticket; include a diag report captured as soon as possible after such an event occurs and also enable RA. Finally, I’d post the ticket # here.
I’ve had the same instability issue with the various 8.5.2 Beta/RC versions on BR1 devices with Quectel modems.
I’m seeing issues now where the Wi-Fi as WAN connections will disconnect as soon as you start a cell module upgrade. First time experiencing this. 20X Cat7 HW3
Same issue with the random reboots with my 20X. I ended up downgrading back to previous version and have had no more reboots. Also updated a B One 5G which is a synergized device and it has been fine. Seems to only be an issue with the 20X.
Thanks for the input from other Balance 20X users who are experiencing the same problem (with rebooting anyway).
I have created a Ticket now with Peplink (#25050892) and pointed them in the direction of this post also, so hopefully they can also keep others updated as this appears not to be an isolated issue.
Just an additional datapoint, our Balance20x has remained stable after the upgrade to 8.5.2. One big difference with those with issues above is that our Balance 20x Wi-Fi AP is turned off. We use external AX Lite APs instead. The B20x is only used for AP management. Could WiFi be part of the issue?
While our B20x has remained stable with 8.5.2, we saw a 50% augmentation in the idle traffic on the Backup Cell Link, even though it has not activated since the upgrade. I wonder if there are still some DNS Proxy packets leaking to the backup link like we had in 8.5.0, partially fixed in 8.5.1 (still leaking with DoH enabled), supposidely fully fixed in 8.5.2.
Throwing in here, we have multiple B20x’s that starting randomly rebooting with the 8.5.2 update. We’ve rolled all of our back to the support prescribed 8.5.1.
WiFi WAN could definitely have something to do with it. I had to disable WiFi WAN on the 2.4Ghz band only to get the router (BR1 5G Pro with Quectel modem) stable and not rebooting every five minutes again and again during startup.
Hi - first time poster here. Just want to add that I am facing the exact same problem with my Balance 20X since the Firmware upgrade including random reboots and 500 Internal Server Error. Never had this issue before.
FYI - rolling back to 8.5.1 stabilized the devices. And support also provided a 8.5.2 firmware with a “fix”. Also stabilized the devices we put that one on.
Different hardware (BR1 mini 5G) but also a problem with 8.5.2. It broke support for OpenVPN site to site (via Advanced menu option). Deleting the config for OpenVPN and uploading a new .ovpn file won’t work, rolling back to 8.5.0 did fixed it.
I also rolled back my B20x to 8.5.1 for the same issue. What build is the firmware 8.5.2 with a “fix”? Is the build available, or just being used for your ticket?
Version is provided with a ticket , build is fw-b20x-8.5.2s051-build5591.bin
Seems like it fixing the issue of peplink 20x restart by itself .
Will this be rolled out GA? I still see 5581 on the firmware download page.
Thanks for the information! How is everyone rolling back to 8.5.1 w/o access via the web interface?
With IC2 you can roll back, as long as your B20x connects to IC2. I believe this might also be doable with the CLI if you have it enabled. If IC2 or CLI are not enabled, and you can’t access the UI, then I am not sure what the best approach might be (support can likely help). But maybe you could regain enough stability to login into the UI if you do a hard reset, then switch back to 8.5.1 in the UI, then reload your backup config after the reboot to 8.5.1. There might be easier steps, so if it is that bad for you, you might want to open a ticket with Support to get it done right.
Same random reboot issue with 8.5.2 build 5581 on Balance 20X. 7 times in the past two weeks. Looking forward to some more announcement from Peplink about this issue.
I do see [Known Issue] [8.5.2] Balance 20X - Unexpected Crash - Announcements - Peplink Community with a bit of information, but pretty minimal and it was not clear to me if the mentioned affected version 8.5.2s026, 8.5.2s042, or 8.5.2s051 are the same as the 8.5.2 build 5581 I experience this reboot issue with.
Issue seems to be fixed in 8.5.2s056 build 5930
