We are pleased to announce that Firmware 8.5.0 RC 3 is now available.
I don’t see the firmware download option for DOM-PRO-DUO-5GN-PRM. However confirmed with Peplink support that LR Dome version could be used. ![]()
Would be really nice if you released a .raw as well for the FusionHub, or if you worked with Vultr to have FusionHub as a quick deploy, packaged app. Please consider making it less annoying to get a FusionHub virtual appliance on this popular hosting platform.
We are working on both resolving Vultr deployment issue and update .raw. Things are work in progress and stay tuned. ![]()
The Vultr folks made some sort of tweak in response to a support ticket, and that got the 8.0.2 raw file up and running. From there, I was able to update the virtual machine to 8.4.1.
The Vultr support folks passed this along. Maybe something to consider?
Peplink could become a vendor and build a one-click solution, you may try reaching out to them and make the suggestion as an active customer.
Is there more information available on the updated feature: Adaptive FEC for SF VPN ?
Is there more information available on how to configure Assisted Roaming for Managed APs acc. to 802.11v standard on a Balance Two router? How to configure that for a bunch of AP One AX managed by IC2?
