We are pleased to announce that Firmware 8.5.0 RC 1 is now available.
Important Note: If you are using Starlink, please do not use this firmware version. We have confirmed an issue that affects connectivity with Starlink.
I tried it on my HD2-MBX and Max Pro BR2 where each has a Starlink Terminal and it says Starlink Outage (Okay)
I had to back down to 8.4.
I had the same issue and reverted back to 8.4.1
Lai - Yāall are welcome to access my HD2-MBX and troubleshoot this if you need.
My wife is streaming off the BR2, so please donāt load new code/reboot that one.
My account is under Zenith Communications.
I have the same Starlink Outage (Okay) error on a B20X⦠went back to beta3.
Same I canāt use it, it says starlink outage (Okay).
But thank you for this!
32665 [RC1][CLI]
AddedCLIsupport forbcreating/deleting clientsbandbgenerating/brevokingtokens All Models.
This will allow us to more securely interact with creating tokens, well done team peplink!
Also Iām excited to test this as well.
32693 [RC1][Starlink]Fixed the issue of Starlink WAN being shown as connected without an active account.
I reported that we need the ability to still access starlink.com , but mark the wan as down when the account is either inactive or outside of the location, i.e. fixed plan when traveling.
I didnāt see the option to revert back to beta 3, so I went to 8.4. I just got a new Standard Gen 3 Starlink and havenāt taken it out of the box. I will pair that with a BR2 a customer of mine bought off Amazon and test 8.5 RC1 again next week. Iām trying to get a couple BR1 5GN Pros from another customer to also test with, I will probably just synergize those once they have the latest code and hang them off the HD2 MBX.
Thank you for reporting the Starlink WANs outage issue.
We have confirmed that the problem was caused by a recent update in version 8.5.0RC1. We will address this and provide a fix in the next 8.5.0 RC.
@Lewis_Kong Thank you!
All clients still type āunknownā for me in local web interface client list (B One)
Post here:
I was mistaken.I was looking at the wrong BR2 Proā¦
Whereās the IPv6 support?
