We would like to announce that Firmware 8.3.0 RC 3 is now available.
Supported models:
X Series, Balance, MAX, MediaFast, FusionHub, UBR, SpeedFusion Engine, Surf SOHO
Supported models:
Hello @Lai ,
This is a new one; we’ve never seen Peplink not allow backward compatibility on the firmware configuration.
File: “firmware-8.3.0rc3-release-notes.pdf”
Important Notices
Reference: 16675
Description: [RC 3] [System] Updated configuration file version. The configuration file for Firmware 8.3.0 is not compatible with firmware versions 8.2.1 or below.
Device Supported: All Models
Two questions:
Happy to Help,
Marcus ![]()
We have checked and this is a WebUI bug. We will fix this for the next coming RC firmware. Thank you for letting us know.
Yes this concerns us as well.
Hi I have some bug on the firmware, when I select on the remote User access page the VLAN wich is used to connect Client the configuration is taken in account but UI interface doesn’t change at all and reset itself when I select the save button
thanks in advance
Thanks for your feedback, we will fix this bug in the next RC version.
Unable to add Local DNS Record
Either a bug, or procedural change - cannot add local DNS record in 8.3.0.x (process works perfectly in FW 8.2.1).
Is there a new/additional step or configuration required now?
Upon clicking the save button after adding the entry, this error occurs.
I filed a ticket on RC2 , looks like it still an issue on RC3
Thanks - looks like I missed that under the RC2 thread.
@Lee_Zim I’m not sure I posted under RC2, I think I raised a ticket.
@Oh_Yaw_Theng Can you please advice on ticket 22120613 and if the concern raised by myself and @Lee_Zim will be fixed in RC4 ?
Hi dear friends, this problem has been fixed in RC3.
I still have this issue on a 380x 8.3.0 build 5546 is that the latest version?
@Jonathan_Pitts, I was also having this issue on a 310x starting with RC1. Just had a chance to upgrade to RC3, and it does fix this issue.
The newest version is 8.3.0 build 5552. Here is the link for 380x. https://download.peplink.com/firmware/epx/fw-epx_mbx_sdx-8.3.0-build5552.bin
I’m very surprised by this one as well and would love to hear more about the decision and implications.
@Lorance_Tseng @Jonathan_Pitts
FYI…Resolved - I was able to update a test unit to 8.3.0 build5200 (BR1 Pro 5G), and can report this issue has been fixed.
Thank you!
Thank you very much ~!!
Let me explain this shortly ^^.
With 8.3.0 RC3 I am seeing a large increase in logging vs previous releases. Close to 735,000 entries over three days. Most are what appears to be simple DNS requests tied to session logging, which is flooding the logging server on my NAS. Here is an example.
2022-12-27 01:24:55 Info pepwave kern xxxx-xxxx-xxxx Session Logging: SESSION_STATE=END PROTO=tcp PEPROTO=dohdot SRC=(My Cellular IP) DST=8.8.4.4 SNATIP=(my cellular IP) SPT=53612 DPT=443 SNATPT=53612 PACKETS_SENT=12 PACKETS_RECVD=9 BYTES_SENT=1521 BYTES_RECVD=6631 IFACE[OUT]=wan5 IFACE[IN]=local
I have disabled session logging for now.
@Marcus, @Jonathan_Pitts , @Steve_Mitchell
Below are the answer for the two questions:
1 Will Peplink supply a support tool for Partners to copy configurations back to older firmware prior to 8.3.0 when required?
2 Can Peplink elaborate some of the reason for this change?
Hope the above explained the concerns ^^
