We would like to announce that Firmware 8.1.3 Beta 1 is now available.
Supported models:
X Series, Balance, MAX, UBR, SpeedFusion Engine, FusionHub, Surf SOHO
Supported models:
Installed and seems stable in our backup MAX HD2. Thank you.
I’d love to see some beta firmware for Max Adapter for HD2 in 8.1.3. I volunteer to test for you!
David
It’s running well here as well.
Remote Assistance seems to be re-enabled automatically on every reboot with the betas. Is there a way to switch it off?
@Vitaly, I think the behavior explained in this post and the disclaimer (item 2) has been updated. ![]()
Based on the release notes doesn’t seem to be too many new features or updates.
More importantly a few bug fixes and frag attack fix.
I think I won’t wait for this one to go GA and install it this weekend.
Understood.
I do agree with the @Rick-DC in that thread you’ve linked to. Automatically re-enabling RA presents issues. Many of us do not want/need RA running continuously. So this would just prevent us from trying out more betas, or at least introduce an extra manual step upon each beta reboot.
There should really be an option to just disable RA for betas, or to use the current RA flag to control RA availability. IMO.
