We would like to announce that Firmware 8.1.2 RC 3 is now available.
Supported models:
X Series, Balance, MAX, UBR, SpeedFusion Engine, FusionHub, Surf SOHO
Supported models:
installed without issue
Same here. Works well!
Edit: On MAX Transit LTE-A
Where do we submit feature enhancements? I’d like to use the groups for QoS. Staff, guest and manager isn’t enough imo.
Hello @Lai,
We have had an issue with this release when upgrading RC2 to RC3 on FusionHub when hosted within AWS; all details are within ticket 21041113.
Happy to Help,
Marcus
Hello @Lai
I am having an issue with this release (10.0.x.x devices try to connect to Google DNS several times a minute). See ticket nr. 21050012
We have similar request here: Add more User Groups for QOS - #6 by Andres_Bonilla
You can send your request via the above link.
We are checking your ticket.
@ckirch ,
Support team will follow up with you via ticket. Just to confirm you only see that in firmware 8.1.2 RC3 ?
Yes, exactly, not with 8.1.1 GA.
Any updates?
New FragAttaks Wifi vulnerabilty. Will PL fix this until GA release?
See https://forum.peplink.com/t/ap-one-firmware-3-9-0-rc-1/35990/2?u=ckirch
Seeing a severe bug on a SDX PRO with 580 speedfusion peers (we are migrating from three B710s to an SDX PRO).
Status->speedfusion does not update.
Far more critical - the API call to vpn status returns nothing. This is a critical issue as we use the API to manage devices.
@jmpfas, for the number of profiles not up to date at Status > SpeedFusion, we will investigate.
Can I confirm the API here is referring to router API - https://download.peplink.com/resources/Peplink-Router-API-Documentation-for-Firmware-8.1.2.pdf?
Thanks.
