8.0 RC4 is released:
Hi sitloong,
Will, the PepVPN / SpeedFusion in FW8 be compatible with PepVPN in AP One models with current firmware? We tried establishing connection between an AP and B305 with FW8 RC2 but failed due to incompatibility of SF versions.
@JakubN, can you share your application use case that needs to establish PepVPN between AP One access points to the Balance 305?
At the same time, we will verify the PepVPN Engine “incompatible” issue as you tested and revert accordingly.
Hi Wei Ming,
we plan to deploy AP Ones behind ISPs firewalls in several locations and manage them with a Balance in the HQ.
Simple connection map:
AP Mini >>> L2SF >>> ISP Firewall with open ports >>> Balance 710 with public IP
