With Firmware 7, everything is better. MAX single cellular routers have a lot of added functionality. Dual-radio devices can now do simultaneous Wi-Fi WAN. The Port-Based VLAN feature is now available for more devices, and out-of-band management is possible for UART enabled devices.
Enhanced Functionality for Single Cellular Routers: The BR1, BR1 Slim, and MAX Transit are now equipped with SpeedFusion WAN Smoothing, Load Balancing, and High Availability! This makes them much more powerful contenders in the single-cellular market.
Simultaneous Wi-Fi WAN: For the Surf SOHO MK3 and the MAX Transit, the 2.4GHz and 5GHz radios can both operate as Wi-Fi WAN.
Extended Support for Port-Based VLAN: The Port-Based VLAN feature has been extended to a number of Balance models.
Out-of-Band Management Support: UART enabled devices can now be used to perform Out-of-Band Management, remotely accessing another device even if it loses connectivity.
This is just the tip of the iceberg. Take a look at our release notes to see all the improvements we’ve made. Play around with it and let us know what you think!
Cannot seem to change the WAN Connection Name on a Balance One router running the Beta 7 firmware. It keeps defaulting back to “WAN 1”. No amount of saving or rebooting makes it take the new name.
I am trying to install this Beta firmware 7 on a MAX BR1, but it says “invalid”?
I’m running now 6.3.3 build 2252, and connected with a UTP cable
The firmware I selected: fw-max_br1_br2-7.0.0b01-build2390.bin
Afternoon
I was just testing the issue mentioned by Xerxes and found that upon clicking apply settings, the name change would not work and the WAN would disconnect then reconnect. The Balance ONE Core has a public IP address as the providers router is in bridge mode.
Another issue I have had is the router has rebooted its self twice in the last 24 hours. Both times there where no settings changed on the router and minimum load on the WAN.
Thank You
I have a question about FW release 7 and the end of support for hardware.
The Peplink website mentions that only “Firmware 6.x maintenance releases” will be supporting older hardware.
Can you please let us know when the following HW versions will no
longer be supported by Peplink? We need that information because we need to
be able to plan migration to other hardware.
Right now, we have no plan to discontinue the support for these models. We know our customer base demands long-term reliability and support of our products. Therefore, as long as the products are in-warranty, we will provide the needed support.
Thanks Keith,
When the time comes that Peplink decides support of any hardware must discontinue, what is the minimum lead time we will be given ?
Cheers
Dana
