End of Support lead time will be at least 3 years. We will update our support policy to reflect some of these details.
Evening Guys
Just noticed that the bandwidth reports have changed and now display two entries both with the same IP address but only one displays a MAC address. Bandwidth counter is different for the two identical Eps but is in line with what we would expect from that device.
Any ideas?
Also noticed that there is now a PepVPN/SpeedFusion data usage tab. LOVE THIS!!!
Thank You
This is a bug and will be solved in the coming firmware release.
Thanks for reporting this!
Good Evening Guys. Just notices the following inconsistency on a MAX Transit DUO which was installed this evening. Web admin (local and accessed remotely via IC2) shows 1.49 GB data used on all WANs (reasonable and expected) but the IC2 interface is showing 1520.63 GB!
I think a GB/MB/TB translation is missing a zero or two one way or the other!
The only other instance we see similar is on the Balance ONE Core we are testing with 7.0.0 but only on the Monthly data usage on IC2 (all other displays are correct and true)
Customer said they used a lot of data but 1.5TB in 6 hours on a 30Mb/s connection is taking the piss! (Max data throughput at full throttle would be 81GB! over 6 hours)
All images attached are relating to the Transit DUO.
RA enabled on both devices. Serial number ends in F5FC 7.0.0 build 2692 for the DUO and 79CF 7.0.0 build 2692 on the B1 Core
Thank You
Thank you for reporting this as well. This has been fixed in the upcoming RC release.
