Can anyone post a graph of a successful speedfusion bonding of ATT + Verizon that achieves noticeably faster speeds over one alone?
Has anyone gotten better results bonding ATT + ATT or Verizon + Verizon over ATT + Verizion?
I have spent weeks trying to tune the Fusionhub tunnels and the short answer is…
NOPE.
Any single WAN (ATT and/or Verizon) has faster download and upload, fewer packets lost, and far less latency, than a bonded connection between the two. I have a service ticket open now and am waiting for response.
Jason??
I ran into something the other day in the context of a different experiment, where the aggregation of lines definitely was better than a single line.
Background:
Observations:
Test:
Observation:
Conjecture:
Might SpeedFusion be so sensitive to latency differences that the 150ms extra for one line over the other caused the slowdown?
I have dismantled the test set-up, so this is it for now.
Cheers,
Z
Even though Visible is on VZW’s network, I am going to guess its given a lower network priority.
I sent you a private message but I am curious which Visible plan you have and how you got it to work with the Peplink?
Thank you!
That is indeed the case.
There is only one plan. For a Peplink device configuration of an activated visible SIM card see Max BR1 Mini LTE or LTEA on Verizon - #7 by Jonathan_Pitts.
Cheers,
Z
Thanks for the shared plan idea, I’ll do my own for now.
There’s even an FB page to get groups of four together ![]()
We’re likely to abandon our visible.com test, it does not work for our particular use-case (mixed-in with regular Verizon lines)
What didn’t work about it?
The combination with Verizon lines did not seem to work well in a SpeedFusion combination. My conjecture is that the 150ms consistent latency add-on played havoc with it, but that is just a guess.
You can adjust parameters that will pause a connection in a bond if the latency rises to a specified amount. This makes a significant difference. Look at my dialog with Martin Langmaid about this.
Did you (or anyone) try running 2 Visible SIMs on the Verizon Network compared to 2 Verizon SIMs?
