Mobility Antenna
In order to align our range of antennas to their specifically engineered verticals, we will be revising some names and SKUs.
Since this is a running change, in the coming future, the PUMA antennas will be renamed to the Mobility Antenna. This change is reflected on the webpage and datasheets already and once the new SKU is ready (inc packaging), then this will be completely replaced on the eStore.
This does not mean they’re restricted to usage within that vertical only, they’re actually applicable to various verticals!
FAQs
Why has the PUMA Antenna become the Mobility Antenna?
The PUMA Antenna has been engineered specifically towards mobile applications, although it can cater to various verticals. In order to align our product names for future antennas, we have decided to revise them all to reflect the relevant verticals.
Will the MSRP of the Mobility Antenna change?
The MSRP remains unchanged.
Are there any specification differences?
No, the specifications are exactly the same. The only difference is the SKU and Name.
How do I read the new SKU to confirm my selection?
Actually the ordering is quite the same. For example, the PUMA 421 in Mobility Antenna SKU will be ANT-MB (MB for Mobility) and the 3 numbers following will become 42G, to indicate:
- 4 (4x cellular)
- 2 (2x Wi-Fi)
- G (1x GPS)
The following characters remain the same. Please see the screenshot below.
Quick Reference
| Product code | Product Name | ||
| OLD | NEW | OLD | NEW |
| PUMA-401-S-W-6 | ANT-MB-40G-S-W-6 | Puma 401 | Mobility 40G |
| PUMA-401-S-B-6 | ANT-MB-40G-S-B-6 | Puma 401 | Mobility 40G |
| PUMA-401-Q-W-6 | ANT-MB-40G-Q-W-6 | Puma 401 | Mobility 40G |
| PUMA-401-Q-B-6 | ANT-MB-40G-Q-B-6 | Puma 401 | Mobility 40G |
| PUMA-401-Q-W-1 | ANT-MB-40G-Q-W-1 | Puma 401 | Mobility 40G |
| PUMA-401-Q-B-1 | ANT-MB-40G-Q-B-1 | Puma 401 | Mobility 40G |
| PUMA-401-N-W-6 | ANT-MB-40G-N-W-6 | Puma 401 | Mobility 40G |
| PUMA-401- N-B-6 | ANT-MB-40G-N-B-6 | Puma 401 | Mobility 40G |
| PUMA-201-S-W-6 | ANT-MB-20G-S-W-6 | Puma 201 | Mobility 20G |
| PUMA-201-S-B-6 | ANT-MB-20G-S-B-6 | Puma 201 | Mobility 20G |
| PUMA-201-Q-W-1 | ANT-MB-20G-Q-W-1 | Puma 201 | Mobility 20G |
| PUMA-201-Q-B-1 | ANT-MB-20G-Q-B-1 | Puma 201 | Mobility 20G |
| PUMA-221-S-W-6 | ANT-MB-22G-S-W-6 | Puma 221 | Mobility 22G |
| PUMA-221-S-B-6 | ANT-MB-22G-S-B-6 | Puma 221 | Mobility 22G |
| PUMA-221-Q-W-1 | ANT-MB-22G-Q-W-1 | Puma 221 | Mobility 22G |
| PUMA-221-Q-B-1 | ANT-MB-22G-Q-B-1 | Puma 221 | Mobility 22G |
| PUMA-020-R-B-6 | ANT-MB-02-R-B-6 | Puma 020 | Mobility 02 |
| PUMA-020-R-W-6 | ANT-MB-02-R-W-6 | Puma 020 | Mobility 02 |
| PUMA-020-Q-W-1 | ANT-MB-02-Q-W-1 | Puma 020 | Mobility 02 |
| PUMA-020-Q-B-1 | ANT-MB-02-Q-B-1 | Puma 020 | Mobility 02 |
| PUMA-421-S-W-6 | ANT-MB-42G-S-W-6 | Puma 421 | Mobility 42G |
| PUMA-421-S-B-6 | ANT-MB-42G-S-B-6 | Puma 421 | Mobility 42G |
| PUMA-421-Q-W-1 | ANT-MB-42G-Q-W-1 | Puma 421 | Mobility 42G |
| PUMA-421-Q-W-6 | ANT-MB-42G-Q-W-6 | Puma 421 | Mobility 42G |
| PUMA-421-Q-B-1 | ANT-MB-42G-Q-B-1 | Puma 421 | Mobility 42G |
| PUMA-421-Q-B-6 | ANT-MB-42G-Q-B-6 | Puma 421 | Mobility 42G |
Help! The Peplink E-store indicates ‘no results found’ when I try searching for the new SKU (ANT-MB).
Since this is a running change, the new SKU (ANT-MB) will not be displayed; instead, the current SKU (eg. PUMA-401-N-B-6) will persist until further notice.
So, what’s the point? This is adding unnecessary confusion to our ordering process.
As Peplink and stocking partners still have stock of the current PUMA SKU, we will continue this running order until stock levels have cleared. Only then will the new SKU be implemented in our e-store. To reiterate, the SKU ANT-MB and the PUMA- remain exactly the same. This arrangement acts as a pre-notification for our upcoming plans for the antenna range.
When will the new SKU (ANT-MB) come into action? Will I be notified?
Only when the stock levels have cleared for each product will the new SKU be implemented. Therefore, it is difficult for us to indicate an exact time for each model, especially when some SKUs are more popular than others. Where possible, we will aim to provide notification of any changes to any of our SKUs.
