External Captive portal
Can somebody help me with setting up an external captive portal
I have 2 pages designed in HTML
When the user clicks on connect on page on I would like them to be directed to page 2.
I can find information about PHP but I was hoping there is some simple code out there for HTML to achieve what I need.
I would use the inbuild portal but there are a few bugs with it relating to the frame outlines
I can likely help. Did you see the source code on my old custom captive portal template?
https://www.slingshot6.com/blog/free-peplink-captive-portal-splash-page-template/
Alsp see here: Configuring an External Splash Page for Captive Portal
