I would like to know if Peplink products support flat network deployment between 2 different locations that are on same subnet?
Let’s say, I’m on Site A with IP of 192.168.100.100 and I have a server on Site B with 192.168.100.101. I want to use Internet links and configure SDWAN tunnel between 2 sites but having LAN subnets on the same network.
Hi. It appears that you want to set up a L2 VPN with PepVPN or SpeedFusion. As it happens, there has been a fair amount of discussion here about how to do that. Not difficult. See, for example: Setting up a Layer 2 PepVPN Profile in Firmware 6.2 Onwards. @MartinLangmaid, in particular, has discussed this a number of times here.
Suggestion: Try the link above and see if it’s any help. If you get stuck let us know!
If both sites are on default vlan1, can we extend that default vlan on both sites? Or do we need to put both networks to a vlan other than that of default vlan to make this work.
