ESIM instalation not via in control
Hi Peplink Team,
I wanted to ask if it’s possible to add an option to install eSIMs directly via the local WebUI, rather than exclusively through InControl.
I work with a shipping company, and just last week one of our vessels exceeded its data package. I intended to guide the crew through installing a new eSIM onboard, but we discovered that this option isn’t available outside of InControl.
It would be very helpful to have this functionality locally, especially in remote environments where access to InControl may be limited.
@Giedrius Can you evaluate?
Liked:
I agree this would be helpful if there is a network issue, or if remote personal are not allowed to incontrol2.
If we could start a esim request local from the device that would be very helpful.
Agree that would be super helpful.
Jonathan and Przemek provided further insights into use cases where installing eSIMs directly through the local WebUI becomes necessary:
  1. Minimizing data usage. In scenarios such as being offshore, if the local SIM reaches its data cap and the only available fallback is an expensive connection like Iridium, even InControl2 (IC2) traffic may be disabled. However, the Iridium link could still be used to upload a new BYO eSIM profile directly via the WebUI, avoiding unnecessary overhead.
  2. Some organizations may choose never to connect their devices to IC2 due to strict internal security policies or compliance requirements.
  3. IC2 might be blocked either by the organization itself or by the Internet Service Provider, preventing remote management.
  4. Large organizations may not permit external MSPs to manage their devices within a broader IC2 group. While they may allow local access to the router, IC2 currently lacks fine-grained access controls-such as the ability to assign permissions per tag or restrict access to a single device within a group.
We will bring this topic for internal discussion.
@Giedrius
Can we please get local ui esim activation added to firmware 8.5.3 ?
@Giedrius like above 8.5.3 will be good firmware for this functionality
Hi Przemek,
At present, this request is not in our short-term plans, but we value the feedback and will review it in the future planning.
Hi Giedrius,
I’ve always appreciated being part of the Peplink ecosystem and believed in the vision that every user’s needs are valued. However, I must admit I’m a bit disappointed.
When operating on Iridium Certus 200 — due to its limited bandwidth (176 kbps) — InControl2 struggles to stay connected, making it nearly impossible to upload a new eSIM remotely. This situation undermines the reliability we expect from a global solution.
I find it frustrating that, despite Peplink’s partnership with Iridium, no local fallback method is provided for eSIM upload. It would be a great improvement if there were a way to manage this directly on the device, especially in remote maritime scenarios.
Shortly this wasn’t nice, and thanks for feedback
Is there any update on this subject? When will this functionality be available on the local dashboard?
I would also like eSim (and any other feature) to be available on the web UI, and not need in control. InControl is basically a big security hole. When (not if) Peplink is cracked, the bad guy will now have complete control over any device which uses InControl. This is much to big of an attack surface to be happy using. I only turn on InControl when I have a specific need to.
I hate to have to turn on InControl when I shouldn’t need to, like when I want to install an eSim.
did you try pushing one esim using the EID of the modem?
How if there is not such option
In the cellular details you should see the EID of the modem
And you should be able t osend your esim to this eid then restart the router to fetch it. Not sure whether triggering the esim discovery from incontrol is mandatory
@Giedrius This keeps coming up , the same use cases as before, How did the internal discussions go?
@Giedrius , @Eddy_Yeung
We really need to be able to add esim locally for the reason previously mentioned and confirmed by @Giedrius in Jul/25 , ESIM instalation not via in control - #4 by Giedrius
Can you please have an engineer work with myself for Verizon, and @ChristopherSpitler for Tmobile to test this.
Separate from this forum post there are countless posts requesting loading esims via the local ui. This is also possible on Digi, Teltonika and Ericsson.
If it’s triggerable via incontrol2, the logic and api’s are literally already in place on the router and should be able to be added to the ui, even if only on the support.cgi page.
Hello Giedrius, is there any update on this request? We are experiencing the same issues mentioned by Jonathan and Przemek. The ability to activate eSIMs without requiring an InControl2/Care Plan would be very helpful for us.
for example,some government, military projects restrict the use of InControl2, so installing eSIMs directly via the local WebUI would be very useful to meet their project specifications
Is there any update on this case? It has been almost a year since we first reported this issue.
Thank you.
Hi team,
I’d also second this request. Getting eSIMs installed locally to the device is crucial for my use case and unfortunately a red flag for Peplink devices in comparison to other manufacturers. Buying a PrimeCare plan solely for this feature is overkill.
Will this be considered from the Peplink team in the future or never gonna be possible?
Simon
Any update on this issue, or is this simply a way to generate additional revenue by forcing customers to purchase a Care Plan?
