Deploying FusionHub on AWS
#1
FusionHub is the virtual SpeedFusion appliance from Peplink which allows you to establish SpeedFusion connections between cloud servers and physical Peplink devices, among those supported is Amazon Web Services/AWS.
You would need to provide the following information to trial@peplink.com to begin -
InControl2 account username
● Amazon EC2 region (e.g. Oregon)
● 12-digit Amazon ID
Peplink will then private share the AMI image to your account:
Once you’ve been notified that you have the FusionHub instance, login to your AWS Management Console -
Once logged in, select AMIs under Images -
At the top, locate Filter and pick Private images​.
aws3
Click on Peplink FusionHub​ and a blue dot appears to show that it’s highlighted.
Click Launch​ -
In the next screen Choose an Instance Type, click “t2.micro​
Then click “Configure Instance Details​” at the bottom right of the page.
The “Configure Instance Details” page allows you to make changes to the
Instance details and network interfaces. If you’re unsure what these should be,
then please skip this step.
Click Review and Launch at the bottom right
In the next page “Review Instance Launch”, click on Edit security groups​.
Configure​ the Basic Security Group settings as follows:
● Remove SSH
● Add TCP 2222/32015
● Add UDP 4500
● Add HTTP/HTTPS
Note - If you have other services/applications/specific ports that need to route through the FusionHub instance, ensure they’re configured here as well.
Click Review and Launch​
Confirm that the details are correct, and then click Launch​.
In the left hand panel, expand “Instances” and click on Instances.
Select FusionHub’s running instance​ by clicking on it once.
You’ll need to generate a Security Key to complete.
  1. After highlighting the running instance, right-click to bring up the context menu​.
  2. Click on “**Change Source/Des. Check**​” in the context menu
Select Disable Source/Dest Check​ -
Note FusionHub’s public IP address​.
In your web browser, type in the following to access FusionHub’s administration interface -
http://[FusionHub.instance.public.ip.address]​
Go through initial configuration for FusionHub. Check to make sure all settings have been configured correctly, and then click ​Save and Apply settings ​to confirm when done.
You will be redirected to the ​License Information​ screen. The default ​License Information
dialog looks similar to the following:
The License Key​ referenced is the FusionHub license key obtained from the InControl2 webpage. Please refer to ​FusionHub License Generation​ for details on creating this license key.
Click ​Submit​ after filling the form.
When the license is successfully activated, you will see the following screen:
Once complete, settings should look like this -
FusionHub and Cloud Platform integration (AWS, Azure, Google Cloud)
