Thanks for the email Marcus.
…maybe I’m missing something… have I posted this in the wrong area? Did I accidentally post it as a bug or service request or fault? If so… I apologise & please ignore as it was only a +1 on an existing post for feature request?
As you know, I did attempt contact last week… have I done something wrong by posting here? Your email suggests I shouldn’t have posted here, and should route this through local service agents rather than use the online community?
I’m sorry… perhaps I’ve misunderstood the purpose of the online forum / discussion?
My comment on this was just a +1 on an existing feature request. So there I was googling for others who are encountering the same ddns issue… found the feature request thread… added my +1.
I’ve explained that this is 4G, and explained why NAT is necessary and desirable, and thus why in a monitoring scenario the internet IP is necessary.
I will note that when the peplink does update, it already updates using the internet IP… but it fails to do so regularly, and seems to wait for the WAN IP to change instead? Seems to me that all the hard work in determining what the internet
IP is has already been done… what is missing is a setting to determine update frequency, or at least be smart enough to self-determine when the internet address has changed???
Other posters in the thread have pointed out that far cheaper routers have mastered the ability to report internet addresses in this scenario and for the user to determine update frequency. I too am surprised it is not already in the Peplink
given all the other code to support ddns is already in there?
Using in control 2 then writing a custom applet to pull out the last detected IP…Yes I’m sure we could all do that - we could all develop a custom app… or… a simple update interval setting could be added once by the manufacturer and then
negate the need for the same code to be researched, developed and implemented and maintained by every customer who needs this basic solution.
…seems such a simple feature request, and one that other manufacturers have easily grasped the value of… kind of puzzled why I got this response… but all good
It’s just a feature request…
Have a good day
Sent on the go with Vodafone
