Model: Pepwave MAX Transit running the latest 8.0.1 code just purchase a month ago.
Issue: I have a couple of SSIDs set up for business and home use. A couple of devices that I have used for a while previous to getting the MAX DUO are having Wifi stability issues. These are using 2.4Mhz connections. Originally they were on an SSID that was 2.4 or 5, but due to the issues I created a new SSID that is 2.4 only. Same issues with this one. If I reboot the MAX DUO or restart the AP in some fashion they will connect without issue. After a period of time, a few hours to a few days, the devices will drop on and off the network until eventually, they stop connecting at all. Any thoughts or other things to try?
Also, in my current location, I have a WAN over 2.4WiFi connection setup and I have noted it drops many times a day. Not sure if this is related as the device drops were an issue before I set up this connection.
