Configuration of the new Starlink GPS feature
Is there any special configurations to inControl or the Router (830x in my situation and no gps module but i’m assuming this is the point of this feature) for InControl to access the starlink antenna’s GPS data to display that antenna location in the InControl gui?
I am aware of the setting in the Starlink account/antenna “location request mode” then local but is there anything else that needs to be done?
I changed this setting in my starlink account on a few antenna’s but the location is not updating in inControl. Just updated one router to the 8.4.1 build 5791 and having no luck yet.
Thanks in advance
So i’m guessing its not working due to this known issue i just seen? can anyone confirm or deny and does anyone know when this may be resolved.
31834
Starlink GPS support is lacking on models without
integrated GPS
Did you enable the starlink integration on the network WAN of your 380x as well?
Yes Sir, I’ve had this setting configured since the last update. But now that you mention it I think i’ll disable and reenable just for kicks… This feature is huge for my vessels. Since I only use 830X without the cellular modules it will be great to track the ships with this method. I have 2 Maritime systems on each vessel. I’m not sure if this is an issue or not.
Do you see any GPS menus , with it enabled?
If not, you may need any special firmware.
Send me a PM and I’ll try to track one d for you
Can I ask a question?
Yes what question do you have?
All,
To activate starlink on Peplink Router:
  1. Supported firmware like 8.4.1
  2. Activate Starlink at the WAN
  • If you cannot see the Starlink - then you need to get to the correct firmware.
  1. you will need to activate the GPS on Starlink antenna.
    You can see the photo to activate it.
Great pictures and detailed setup!
Anyone here tried the setup? Does it work?
I have set it up and tested on my starlink demo setup and it works.
no, still unable to figure out on my MAX BR1
What model and firmware are you on that it is not working?
8.4.1 build 5474, it is MAX BR1 LTE-20
thanks
That should be supported.
Have you enabled the options in post 6 ?
yes, as our application used on marine and presently we can only buy via reseller, hence we dont have access to Starlink account but our reseller confirmed they have enabled position sharing, also we have upgraded firmware and select Starlink WAN.
Adding in - I’m on a Peplink B One 5G that does not have an integrated GPS antenna, I do have 8.4.1, I have enabled Allow access on local network in Starlink, I’ve tried the “turn it off and turn it on again” of the Starlink support on the WAN port, and the GPS information does not appear in either local management page nor on the InControl2 page. Wouldn’t mind this to be a feature for the RV just for paranoia / tracking of a rig.
Thank you for sharing detailed info.
Probably you might be hit with the known issue, as outlined in the firmware 8.4.1 - Release Notes.
We can load this special firmware 8.4.1s100 which should fix the issue. The fix shall be included in the next GA firmware.
Would this firmware update allow the devices connected to my B One 5G to access the GPS coordinates provided by my Starlink Gen3?
Hello @BruceM,
The good news is that this special firmware allows you to use the GPS from your StarLink in the new B One and B One 5G.
Happy to Help,
Marcus :slight_smile:
