Configuration of the new Starlink GPS feature
hi Weiming, yes this special firmware works.
When will the new Firmware GA release?
Also will next Firmware support MAX series which have no chance to connect GPS antenna?
thank you
@Jiang_Lin in firmware 8.4.1GA, the GPS data from Starlink is recognized by the models with GPS module.
Hello @WeiMing,
Please share if there is special release firmware for other Peplink models that don’t have an integrated GPS chipset, such as:
  • Peplink Balance 20x
  • Peplink B One
  • Peplink Balance 310 5G
  • Peplink 2500 EC
  • Peplink SDX
  • Peplink SDX Pro
  • Peplink EPX
Appreciate your assistance,
Marcus :slight_smile:
Should be available for all models as of 8.5 beta 2
All,
I documented the steps to activate the GPS on the Starlink App.
Unfortunately, the Starlink App only supported up to 99 Starlink kit and I have more than 100.
Now, I am not able to use the app to remotely enable the GPS info on network for those that are beyond 100.
Is there a way to activate the GPS on network in another way?
Thanks.
I think you can enable on the starlink website?
Jonathan,
Yes, I checked and found out that it is possible to turn it on from the web.
Thanks for your help.
All,
Here is the screenshot for the setting:
Loved the screen shots, I went into the advanced screen and didn’t scroll down far enough, thanks for post!
Does this GPS local access work with the Starlink in Bypass mode (Public IP passed to the Peplink WAN)?
Yes. I have a B One 5G and a gen 3 dish in bypass mode with GPS enabled following the instructions here.
Does anyone know how speed is calculated in the InControl portal? Is Starlink sending the speed or is the Peplink calculating it based on GPS it’s receiving from Starlink. This is for a non-GPS chipped router, Peplink B One. Thanks!
Hi!
This is likely done using SOG (Speed over ground) messages from the GPS. These are predicted speed calculations, so not 100% accurate.
