I have a Pepwave Transit max duo, and some websites I cant access because they say I am running through a VPN, which I am not. Is there a setting for websites to determine the proper location?
Are you using “SFC,” SpeedFusion Connect? If so, this issue has been the subject of repeated discussions. See, for example,
Investigate running FusionHub Solo. You won’t be sharing the IP with anyone else and won’t have the problem you are experiencing.
We are thinking of launching a service for this exact reason, so DM me.
i get the attached error message on a lot of websites when using SFC.
It’s mostly airlines that are affected.
I’m using automatic mode and the router is connected to FRA at the moment.
[grafik]
What are your experiences with SFC?
Thanks and best regards,
Henry
when using the SFC to Frankfurt Germany Peplink is using Digitalocean as provider.
But when using Digitalocean a few sites and services are blocked (because of Digitalocean AS reputation).
Most known service is reddit.com which doesn’t work.
Is there any chance this issue can be solved? Do we need to give Peplink feedback or what’s the best way?
It seems as though Speed Fusion Cloud IP addresses have been included in this latest action by Netflix.
Using Netflix through SFC severely restricted content available. Content that was working last weekend is now inaccessible.
I tested via both San Francisco & San Jose POP. (I live in Bay Area)
https://www.reddit.com/r/netflix/comments/p2uc2o/netflix_not_showing_a_lot_of_moviesshows_only/
I guess people use VPN to watch out of country movies… sigh… I just want to watch in-region movies wi…
If not, please provide details as to how your router is configured vis-a-vis outbound policies and what WANs you are using.
