Cannot get Peplink Balance 20x to connect to comcast modem...
Its been stuck at connecting for several hours. I tried rebooting/resetting both the modem and Balance 20x. I can plug my old router in it and it works fine. The cellular connection works perfectly fine. Any ideas?
yes this is a known bug i discovered back in oct 2020 on firmware 8.1. you can read about it here:
Peplink was able to fix it in a subsequent firmware update…
which firmware are you running?
why are you posting to these ancient threads?
because no one ever responded or helped the OP out.
