New to Pepwave products.
Have a customer that wants us to provide a ACW-411 in addition to a BR1 Mini. They want to connect triggers to the ACW-411 to sense when triggers go high or low. (0VDC to 12VDC)
In my limited knowledge, the ACW-411 is not capable of that. Its only an RS232 interface.
Can anyone fill me in and correct me if I am wrong?
It is just a rs232 interface so they would need something else with GPIO pins to sense the voltage triggers.
Thank you, that is what I expected.
Does Peplink make a modem that accepts inputs that I described?
No.
And then do what? What sort of triggers? To trigger what where?
Hello @SSpitters,
Some of the Pepwave & Pepxim models have “Ignition Sense”, could you use that feature as a GPI (General Purpose Input)? You can find some of the fourms past discussion on this subject at Peplink | Pepwave - Forum or look on the main Peplink website.
The Pepxim Smart Readers have some additional GPI/O connections that may be of benefit to you, there is some information here on the forum at Introducing Pepxim, the TA App, and the Smart Reader!.
Happy to Help,
Marcus
my first thought is the SD-PMU PEPXIM | Software-Defined Power Management Unit
What do you want to do exactly?
Best wishes
Dennis
