We are connecting on wifi on a Max BR1 and trying to use bonjour to connect to RTP Midi. It works when we hardwire our ipad into the system but when connected to the AP we cannot seem to get the ipad to show up. We enabled Bonjour in the settings but something still seems to be blocking the Wifi to LAN connection. Any suggestions?
Hi…
Did you try do disable L2 Isolation?
Yup that is disabled
And… you just enable it?
nothing at “Bonjour Service”?
LAN and WiFi are in the same network?
What firmware are you running?
There seems to be sort of subtle bug with firmware 8.5.0 and 8.5.1 that may involved VLANs, Bonjour, and DNS Proxy settings, as described in these threads:
And reported as ticket 24091109
