Bonjour forward settings on MAX TRANSIT
I would like to setup Bonjour forward settings on MAX TRANSIT DUO and I found it in the manual below:
However, the settings might not exist at Network Settings in my MAX TRANSIT DUO. Could you kindly confirm whether the settings exist or not in MAX TRANSIT?
Thank you for your cooperation.
Hi
Bonjour forwarding is not supported on the Transit DUO or the models below it.
It is available on the HD4 and possible the HD2? (need confirmation)
