I have 3 wireless AP – one guest, one IoT, and one for home network. 3 seems to the max so I can’t afford to have both a dedicated 5ghz and 2.4ghz home network AP. Unfortunately I have devices that can only be used with 2.4 on the network and other devices that are 801.11ac compatible and would benefit from our ISP 120mbps down.
I have tried to find a way to steer those ac devices to 5ghz but from what I can tell they just join either band arbitrarily. My download speeds are cut in half, so I’m looking for a solution.
AP > Profiles > Default (or other if you have more than one profile)
Near the top of the Profile setup is an option for Preferred Frequency
This would affect all your SSID
To make this setting for a specific SSID go to
AP > Wireless SSID
On the SSID setup page there is a blue question mark at the top right. Click on the question mark, you will see an option for Advanced settings. The band steering option will appear
I’m not sure how the Profile and SSID options interact with each other. I would expect the Profile to override, but maybe someone else can verify.
So in reference to my original question, would you say my only option to guarantee device level bands is to have two of my three available wireless AP be dedicated to different bands?
@Andrew_Krueger, based on my understanding, you have 2 type of Wifi devices. One type supports 2.4GHz only but another supports 802.11ac. Both types of devices need to connect to “Home” SSID. You have the problem on 802.11ac devices when they connect to 2.4GHz. Do correct me if I am wrong.
SOHO supports 3 SSID only. I suggest creating SSID below:-
Home_5GHz - For 802.11ac and IoT devices
Home_2.4GHz - For 2.4GHz devices and IoT devices
Guest
Alternatively, please consider upgrading to Balance One.
