We have Peplink Balance 710 (balance Dec 7 ) running on firmware version 6.3.1. Please share the link to the latest available Firmware.
Thanks & Regards,
Ankur Jain
Thanks & Regards,
Ankur Jain
Go to Firmware & Documentation- Peplink and search for “710.” You will see that if you have the aged HW 1 or 2 6.3.4 is the latest. For HW3 8.5.2 is available.
Hi, @ankur.jain and @Rick-DC
For Peplink Balance 305hw1/380hw1-5/580hw1/710hw1-2/1350hw1
Check the file:
https://download.peplink.com/firmware/plb700/fw-b305_380_580_710_1350-6.3.5s020-build3648.bin
Version: 6.3.5s020
You can read about this version at:
Noted. Interesting that once again Peplink failed to present the most recent version on the download page. I guess the use of older versions is encouraged?
Ha ha ha…
Don’t know… but I have four MFA-380 running this version and they can do speedfusion with devices running version 8.4.1s032.
I downloaded the firmware using the link, but it did not upgrade the device. Please advise and provide the direct download link of the latest firmware, the current running version is 6.3.5s020 build 3648
Thanks in advance
Hi, @ankur.jain
About 6.3.5s020.
The direct download link is at my message.
The original message, from Peplink, where you can find the original peplink link file it is also at my message. (EDNS)
The bpl-710 (hw1 and hw2) are too old devices… The version 6.3.5s020 are the last option, posted by Peplink, to get the last version supported by those very, very old devices.
