Balance 380X and EXM-8C Flexmodule?
Hi Folks,
May I use an EXM-8C flexmodule in a Balance 380X router (additional Ethernet LAN/WAN ports)? From the datasheet, it looks ONLY the Cellular Flexmodules are compatible
The idea is to provide a fourth WAN port on an existing Balance 380X…
It’s not possible to use the flex modules in side the Balance 380x or 580x.
The Balance 380x/580x have Flex mini modules and the EXM-8C is a normal module designed for the SDX/SDX Pro & EPX Series.
However another solution would be a Virtual WAN.
More on that here: Virtual WAN FAQ
Let me know if this helps :slight_smile:
Thanks a lot @JoeyJanssen ! Will work on the Virtual WAN option.
Have a great day ahead
