I have a 305 device, which for some reason its screen looks not working (picture attached) no console access, no IP address sharing so I do not have web access, I would really love help
This look like hardware issue. Please contact Peplink support to confirm the issue.
So I read lots of other comments from friends that the same thing had happened to them, and I was finally able to connect with the console. But I could not see anywhere how to reset my unit. Have we not been given the option of such a reset in the CLI commands? As is possible for example in cisco switches or routers
Attaches Log Consol
GRUB Loading stage1.5.
GRUB loading, please wait…
GNU GRUB (PePLink Mar 15 2010) version 0.97 [slcm] (639K lower / 252736K upper
memory)
| Balance 305 v6.1.2 build 3071 |
| Balance 305 v6.1.0 build 2863 |
Use the ^ and v keys to select which entry is highlighted.
Press enter to boot the selected OS or ‘p’ to enter a
password to unlock the next set of features.
The highlighted entry will be booted automatically in 1 seconds.
Booting ‘Balance 305 v6.1.2 build 3071’
root (hd0,1)
Filesystem type is ext2fs, partition type 0x83
kernel /bootdata1.bin root=/dev/ram0 console=ttyS0,115200 console=ttyS1,115200
ramdisk_size=131072 fw=1
[Linux-bzImage, setup=0x2800, size=0x1b7c30]
root (hd0,1)
initrd /bootdata2.bin
[Linux-initrd @ 0xe4d2000, 0x12ed3fc bytes]
boot
[ 0.000000] BIOS EBDA/lowmem at: 0009cc00/0009cc00
[ 0.000000] Linux version 2.6.28.10 (buildbot@build) (gcc version 4.5.3 (cros stool-NG 1.18.0) ) #1 Thu Jul 24 06:54:57 HKT 2014
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
[ 0.000000] BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 000000000f7d0000 (usable)
[ 0.000000] BIOS-e820: 000000000f7d0000 - 000000000f7de000 (ACPI data)
[ 0.000000] BIOS-e820: 000000000f7de000 - 000000000f800000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed13000 - 00000000fed1a000 (reserved)
[ 0.000000] BIOS-e820: 00000000fed1c000 - 00000000fed20000 (reserved)
[ 0.000000] BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffb00000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] AMI BIOS detected: BIOS may corrupt low RAM, working it around.
[ 0.000000] last_pfn = 0xf7d0 max_arch_pfn = 0x100000
[ 0.000000] RAMDISK: 0e4d2000 - 0f7bf3fc
[ 0.000000] ACPI: RSDP 000F8C00, 0014 (r0 ACPIAM)
[ 0.000000] ACPI: RSDT 0F7D0000, 003C (r1 A M I OEMRSDT 11001022 MSFT 97)
[ 0.000000] ACPI: FACP 0F7D0200, 0084 (r2 A M I OEMFACP 11001022 MSFT 97)
[ 0.000000] ACPI: DSDT 0F7D0430, 3DA9 (r1 1AAAA 1AAAA000 0 INTL 2002 026)
[ 0.000000] ACPI: FACS 0F7DE000, 0040
[ 0.000000] ACPI: APIC 0F7D0390, 0054 (r1 A M I OEMAPIC 11001022 MSFT 97)
[ 0.000000] ACPI: MCFG 0F7D03F0, 003C (r1 A M I OEMMCFG 11001022 MSFT 97)
[ 0.000000] ACPI: OEMB 0F7DE040, 0047 (r1 A M I AMI_OEM 11001022 MSFT 97)
[ 0.000000] ACPI: MCFG 0F7D41E0, 003C (r1 A M I OEMMCFG 11001022 MSFT 97)
[ 0.000000] ACPI: SSDT 0F7D4220, 00A4 (r1 AMI CPU_CST 1 INTL 2002 026)
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 247MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 0f7d0000
[ 0.000000] low ram: 00000000 - 0f7d0000
[ 0.000000] bootmap 00012000 - 00013efc
[ 0.000000] (7 early reservations) ==> bootmem [0000000000 - 000f7d0000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000100000 - 00004b9ba0] TEXT DATA BSS ==> [0000100000 - 00004b9ba0]
[ 0.000000] #2 [000e4d2000 - 000f7bf3fc] RAMDISK ==> [000e4d2000 - 000f7bf3fc]
[ 0.000000] #3 [00004ba000 - 00004bd000] INIT_PG_TABLE ==> [00004ba000 - 00004bd000]
[ 0.000000] #4 [000009cc00 - 0000100000] BIOS reserved ==> [000009cc00 - 0000100000]
[ 0.000000] #5 [0000010000 - 0000012000] PGTABLE ==> [0000010000 - 0000012000]
[ 0.000000] #6 [0000012000 - 0000014000] BOOTMAP ==> [0000012000 - 0000014000]
[ 0.000000] found SMP MP-table at [c00ff780] 000ff780
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 → 0x00001000
[ 0.000000] Normal 0x00001000 → 0x0000f7d0
[ 0.000000] HighMem 0x0000f7d0 → 0x0000f7d0
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[2] active PFN ranges
[ 0.000000] 0: 0x00000010 → 0x0000009f
[ 0.000000] 0: 0x00000100 → 0x0000f7d0
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: IOAPIC (id[0x01] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 1, version 32, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.000000] Enabling APIC mode: Flat. Using 1 I/O APICs
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] Allocating PCI resources starting at 10000000 (gap: f800000:d0800 000)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 62831
[ 0.000000] Kernel command line: root=/dev/ram0 console=ttyS0,115200 console= ttyS1,115200 ramdisk_size=131072 fw=1
[ 0.000000] Enabling fast FPU save and restore… done.
[ 0.000000] Enabling unmasked SIMD FPU exception support… done.
[ 0.000000] Initializing CPU#0
[ 0.000000] PID hash table entries: 1024 (order: 10, 4096 bytes)
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 465.553 MHz processor.
[ 0.004000] Console: colour VGA+ 80x25
[ 0.004000] console [ttyS0] enabled
[ 0.004000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.004000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.004000] Memory: 227632k/253760k available (2213k kernel code, 25428k rese rved, 960k data, 284k init, 0k highmem)
[ 0.004000] virtual kernel memory layout:
[ 0.004000] fixmap : 0xfffac000 - 0xfffff000 ( 332 kB)
[ 0.004000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.004000] vmalloc : 0xcffd0000 - 0xff7fe000 ( 760 MB)
[ 0.004000] lowmem : 0xc0000000 - 0xcf7d0000 ( 247 MB)
[ 0.004000] .init : 0xc041c000 - 0xc0463000 ( 284 kB)
[ 0.004000] .data : 0xc0329550 - 0xc041959c ( 960 kB)
[ 0.004000] .text : 0xc0100000 - 0xc0329550 (2213 kB)
[ 0.004000] Checking if this processor honours the WP bit even in supervisor mode…Ok.
[ 0.004016] Calibrating delay loop (skipped), value calculated using timer fr equency… 931.10 BogoMIPS (lpj=1862212)
[ 0.012149] Mount-cache hash table entries: 512
[ 0.016320] CPU: L1 I cache: 32K, L1 D cache: 32K
[ 0.024005] CPU: L2 cache: 512K
[ 0.027157] Intel machine check architecture supported.
[ 0.028011] Intel machine check reporting enabled on CPU#0.
[ 0.032020] CPU: Intel(R) Celeron(R) M processor 600MHz stepping 05
[ 0.041244] Checking ‘hlt’ instruction… OK.
[ 0.061191] Freeing SMP alternatives: 0k freed
[ 0.064006] ACPI: Core revision 20080926
[ 0.090168] …TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.136000] net_namespace: 712 bytes
[ 0.136220] NET: Registered protocol family 16
[ 0.140585] ACPI: bus type pci registered
[ 0.144064] PCI: MCFG configuration 0: base e0000000 segment 0 buses 0 - 255
[ 0.148023] PCI: MCFG area at e0000000 reserved in E820
[ 0.152004] PCI: Using MMCONFIG for extended config space
[ 0.156004] PCI: Using configuration type 1 for base access
[ 0.196845] ACPI: Interpreter enabled
[ 0.200008] ACPI: (supports S0 S5)
[ 0.204008] ACPI: Using IOAPIC for interrupt routing
[ 0.238241] ACPI: No dock devices found.
[ 0.240247] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.244560] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.248012] pci 0000:00:1c.0: PME# disabled
[ 0.252131] pci 0000:00:1c.1: PME# supported from D0 D3hot D3cold
[ 0.256007] pci 0000:00:1c.1: PME# disabled
[ 0.260088] pci 0000:00:1c.2: PME# supported from D0 D3hot D3cold
[ 0.264007] pci 0000:00:1c.2: PME# disabled
[ 0.268087] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[ 0.272010] pci 0000:00:1c.3: PME# disabled
[ 0.276433] pci 0000:00:1f.0: quirk: region 0800-087f claimed by ICH6 ACPI/GP IO/TCO
[ 0.280011] pci 0000:00:1f.0: quirk: region 0480-04bf claimed by ICH6 GPIO
[ 0.284494] pci 0000:02:00.0: PME# supported from D0 D3hot D3cold
[ 0.288010] pci 0000:02:00.0: PME# disabled
[ 0.292373] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[ 0.296010] pci 0000:03:00.0: PME# disabled
[ 0.300370] pci 0000:04:00.0: PME# supported from D0 D3hot D3cold
[ 0.304013] pci 0000:04:00.0: PME# disabled
[ 0.308380] pci 0000:05:00.0: PME# supported from D0 D3hot D3cold
[ 0.312010] pci 0000:05:00.0: PME# disabled
[ 0.316212] pci 0000:00:1e.0: transparent bridge
[ 0.333792] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 *10 11 12 14 15)
[ 0.341659] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 7 10 *11 12 14 15)
[ 0.349343] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
[ 0.357326] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *7 10 11 12 14 15)
[ 0.365021] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) * 0, disabled.
[ 0.374039] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) * 0, disabled.
[ 0.383197] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) * 0, disabled.
[ 0.392333] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 *6 7 10 11 12 14 15)
[ 0.400237] ACPI Warning (tbutils-0217): Incorrect checksum in table [OEMB] - 7F, should be 7C [20080926]
[ 0.409875] SCSI subsystem initialized
[ 0.412423] PCI: Using ACPI for IRQ routing
[ 0.420032] HPET: 3 timers in total, 0 timers will be used for per-cpu timer
[ 0.424010] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.432005] hpet0: 3 comparators, 64-bit 14.318180 MHz counter
[ 0.440132] pnp: PnP ACPI init
[ 0.443203] ACPI: bus type pnp registered
[ 0.461239] pnp: PnP ACPI: found 15 devices
[ 0.465431] ACPI: ACPI bus type pnp unregistered
[ 0.470059] PnPBIOS: Disabled by ACPI PNP
[ 0.474115] system 00:01: iomem range 0xfed13000-0xfed19fff has been reserved
[ 0.481270] system 00:08: ioport range 0xa00-0xa0f has been reserved
[ 0.487626] system 00:09: ioport range 0x4d0-0x4d1 has been reserved
[ 0.493976] system 00:09: ioport range 0x800-0x87f has been reserved
[ 0.500312] system 00:09: ioport range 0x400-0x41f has been reserved
[ 0.506664] system 00:09: ioport range 0x480-0x4bf has been reserved
[ 0.513004] system 00:09: iomem range 0xfed1c000-0xfed1ffff has been reserved
[ 0.520132] system 00:09: iomem range 0xfed20000-0xfed3ffff has been reserved
[ 0.527256] system 00:09: iomem range 0xfed45000-0xfed89fff has been reserved
[ 0.534385] system 00:09: iomem range 0xffb00000-0xffbfffff has been reserved
[ 0.542688] system 00:0b: iomem range 0xffc00000-0xfff7ffff has been reserved
[ 0.549821] system 00:0c: iomem range 0xfec00000-0xfec00fff has been reserved
[ 0.556956] system 00:0c: iomem range 0xfee00000-0xfee00fff has been reserved
[ 0.564102] system 00:0d: iomem range 0xe0000000-0xefffffff has been reserved
[ 0.571243] system 00:0e: iomem range 0x0-0x9ffff could not be reserved
[ 0.577855] system 00:0e: iomem range 0xc0000-0xcffff could not be reserved
[ 0.584818] system 00:0e: iomem range 0xe0000-0xfffff could not be reserved
[ 0.591775] system 00:0e: iomem range 0x100000-0xf7fffff could not be reserve d
[ 0.634851] pci 0000:00:1c.0: PCI bridge, secondary bus 0000:02
[ 0.640785] pci 0000:00:1c.0: IO window: 0xb000-0xbfff
[ 0.646094] pci 0000:00:1c.0: MEM window: 0xfe800000-0xfe8fffff
[ 0.652184] pci 0000:00:1c.0: PREFETCH window: disabled
[ 0.657593] pci 0000:00:1c.1: PCI bridge, secondary bus 0000:03
[ 0.663515] pci 0000:00:1c.1: IO window: 0xc000-0xcfff
[ 0.668832] pci 0000:00:1c.1: MEM window: 0xfe900000-0xfe9fffff
[ 0.674916] pci 0000:00:1c.1: PREFETCH window: disabled
[ 0.680326] pci 0000:00:1c.2: PCI bridge, secondary bus 0000:04
[ 0.686234] pci 0000:00:1c.2: IO window: 0xd000-0xdfff
[ 0.691543] pci 0000:00:1c.2: MEM window: 0xfea00000-0xfeafffff
[ 0.697631] pci 0000:00:1c.2: PREFETCH window: disabled
[ 0.703043] pci 0000:00:1c.3: PCI bridge, secondary bus 0000:05
[ 0.708954] pci 0000:00:1c.3: IO window: 0xe000-0xefff
[ 0.714259] pci 0000:00:1c.3: MEM window: 0xfeb00000-0xfebfffff
[ 0.720352] pci 0000:00:1c.3: PREFETCH window: disabled
[ 0.725749] pci 0000:00:1e.0: PCI bridge, secondary bus 0000:01
[ 0.731672] pci 0000:00:1e.0: IO window: disabled
[ 0.736557] pci 0000:00:1e.0: MEM window: disabled
[ 0.741516] pci 0000:00:1e.0: PREFETCH window: disabled
[ 0.746943] pci 0000:00:1c.0: PCI INT A → GSI 16 (level, low) → IRQ 16
[ 0.753662] pci 0000:00:1c.1: PCI INT B → GSI 17 (level, low) → IRQ 17
[ 0.760385] pci 0000:00:1c.2: PCI INT C → GSI 18 (level, low) → IRQ 18
[ 0.767102] pci 0000:00:1c.3: PCI INT D → GSI 19 (level, low) → IRQ 19
[ 0.773828] bus: 00 index 0 io port: [0x00-0xffff]
[ 0.778622] bus: 00 index 1 mmio: [0x000000-0xffffffff]
[ 0.783845] bus: 02 index 0 io port: [0xb000-0xbfff]
[ 0.788796] bus: 02 index 1 mmio: [0xfe800000-0xfe8fffff]
[ 0.795301] bus: 02 index 2 mmio: [0x0-0x0]
[ 0.799492] bus: 02 index 3 mmio: [0x0-0x0]
[ 0.803680] bus: 03 index 0 io port: [0xc000-0xcfff]
[ 0.808651] bus: 03 index 1 mmio: [0xfe900000-0xfe9fffff]
[ 0.814043] bus: 03 index 2 mmio: [0x0-0x0]
[ 0.818230] bus: 03 index 3 mmio: [0x0-0x0]
[ 0.822415] bus: 04 index 0 io port: [0xd000-0xdfff]
[ 0.827372] bus: 04 index 1 mmio: [0xfea00000-0xfeafffff]
[ 0.832770] bus: 04 index 2 mmio: [0x0-0x0]
[ 0.836952] bus: 04 index 3 mmio: [0x0-0x0]
[ 0.841134] bus: 05 index 0 io port: [0xe000-0xefff]
[ 0.846096] bus: 05 index 1 mmio: [0xfeb00000-0xfebfffff]
[ 0.851484] bus: 05 index 2 mmio: [0x0-0x0]
[ 0.855670] bus: 05 index 3 mmio: [0x0-0x0]
[ 0.859853] bus: 01 index 0 mmio: [0x0-0x0]
[ 0.864033] bus: 01 index 1 mmio: [0x0-0x0]
[ 0.868222] bus: 01 index 2 mmio: [0x0-0x0]
[ 0.872404] bus: 01 index 3 io port: [0x00-0xffff]
[ 0.877193] bus: 01 index 4 mmio: [0x000000-0xffffffff]
[ 0.882497] NET: Registered protocol family 2
[ 0.887099] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.894236] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.901457] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.907992] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.914337] TCP reno registered
[ 0.917649] NET: Registered protocol family 1
[ 0.922424] checking if image is initramfs…it isn’t (bad gzip magic numbers ); looks like an initrd
[ 1.030857] Freeing initrd memory: 19380k freed
[ 1.048735] msgmni has been set to 482
[ 1.052801] alg: No test for stdrng (krng)
[ 1.056944] io scheduler noop registered
[ 1.060883] io scheduler anticipatory registered
[ 1.065504] io scheduler deadline registered
[ 1.069834] io scheduler cfq registered (default)
[ 1.091722] pcieport-driver 0000:00:1c.0: found MSI capability
[ 1.098118] pcieport-driver 0000:00:1c.1: found MSI capability
[ 1.104486] pcieport-driver 0000:00:1c.2: found MSI capability
[ 1.110859] pcieport-driver 0000:00:1c.3: found MSI capability
[ 1.117831] ACPI: Invalid PBLK length [0]
[ 1.122294] ACPI: CPU0 (power states: C1[C1] C2[C2] C3[C3])
[ 1.128147] processor ACPI_CPU:00: registered as cooling_device0
[ 1.134283] isapnp: Scanning for PnP cards…
[ 1.494262] isapnp: No Plug & Play device found
[ 1.510233] Serial: 8250/16550 driver4 ports, IRQ sharing enabled
[ 1.516647] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.522935] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.530758] 00:06: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 1.536830] 00:07: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 1.543836] brd: module loaded
[ 1.547013] Uniform Multi-Platform E-IDE driver
[ 1.551808] piix 0000:00:1f.1: IDE controller (0x8086:0x266f rev 0x04)
[ 1.558343] pci 0000:00:1f.1: PCI INT A → GSI 18 (level, low) → IRQ 18
[ 1.565119] piix 0000:00:1f.1: not 100% native mode: will probe irqs later
[ 1.571988] ide0: BM-DMA at 0xffa0-0xffa7
[ 1.576365] ide1: BM-DMA at 0xffa8-0xffaf
[ 1.868314] hda: TS2GCF160, CFA DISK drive
[ 2.544607] hda: UDMA/100 mode selected
[ 3.116157] ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
[ 3.120758] ide1 at 0x170-0x177,0x376 on irq 15
[ 3.125909] ide_generic: please use “probe_mask=0x3f” module parameter for pr obing all legacy ISA IDE ports
[ 3.135787] ide-gd driver 1.18
[ 3.138907] hda: max request size: 128KiB
[ 3.142914] hda: 3931200 sectors (2012 MB) w/1KiB Cache, CHS=3900/16/63
[ 3.149662] hda: hda1 hda2 hda3 hda4
[ 3.155439] ide-cd driver 5.00
[ 3.158842] stex: Promise SuperTrak EX Driver version: 3.6.0000.1
[ 3.165127] Driver ‘sd’ needs updating - please use bus_type methods
[ 3.172782] PNP: No PS/2 controller found. Probing ports directly.
[ 3.181442] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 3.186399] serio: i8042 AUX port at 0x60,0x64 irq 12
[ 3.191934] mice: PS/2 mouse device common for all mice
[ 3.197689] cpuidle: using governor ladder
[ 3.202202] TCP cubic registered
[ 3.205561] NET: Registered protocol family 10
[ 3.210478] NET: Registered protocol family 17
[ 3.214935] 802.1Q VLAN Support v1.8 Ben Greear [email protected]
[ 3.221697] All bugs added by David S. Miller [email protected]
[ 3.227725] Using IPI Shortcut mode
[ 3.232395] Marking TSC unstable due to TSC halts in idle
[ 3.544112] RAMDISK: Compressed image found at block 0
[ 9.900285] VFS: Mounted root (ext2 filesystem) readonly.
[ 9.906232] Freeing unused kernel memory: 284k freed
[ 9.911375] Write protecting the kernel text: 2216k
[ 9.916329] Write protecting the kernel read-only data: 740k
Initializing…
PLB305
Loading Device Model Information… done
Peplink Balance 305 6.1.2 build 3071
login: admin
Password:
Login incorrect
login: reboot
Password:
Login incorrect
Have we not been given the option of such a reset in the CLI commands? As is possible for example in cisco switches or routers ???
If you are able to connect to CLI you should also be able to connect through the web interface. You can do a reset there under System > Configuration.
No i can not
