I have a new Balance 20X with minimal configuration (no VPN/SpeedFusion, default outbound policy, etc…) but the internet upload speed is much slower than the download speeds.
With a direct wired connection to my Gig fiber gateway, I can consistently achieve ~950 Mbps up and down with speedtest.net from my laptop
When I direct wire to my Balance 20X (which is then connected to my gateway) from the same laptop I can get ~850 Mbps down (expecting this since the max throughput listed for the Balance 20X is 900 Mbps) but only 90 - 100 Mbps for uploads. That’s total upload bandwidth so if I run a test on two devices at the same time the upload bandwidth is split/shared between them (I checked this in case it was limiting per device…).
While I don’t expect full Gig upstream, a 9 or 10 fold decrease seems excessive.
Anything I should check or has anyone else experienced this?
Thanks in advance
